JHZR2
Staff member
My basement shop has poured concrete walls. I was looking to put up a wood strip to affix some additional structure to, but in one spot was an old masonry nail (looks like blacksmith nails) that was sticking out a bit. Of course it was in the way of the spot where I wanted to put the strip.
I tried to pull the nail, and used a prying tool that gave me some good leverage. The nail came out, but it pulled some of the concrete with it.
The hole is between a half and silver dollar size at the surface. At the bottom, maybe 1" in, is about the diameter of an old silver half dime (envision half the size of a dime).
Everything I'm reading says that to fix concrete, the bottom should be chiseled out to be wider than the hole at the top, so that the patch is held in mechanically. There seems to be a lot of suggestion not to just fill concrete with a patch just to smooth the surface.
I'm sort of overthinking this, as the spot is actually going to be behind where the wood is put up. But I'd rather do it if $10 in materials gives peace of mind...
So I'm guessing hydraulic cement and chisel it out wider at the bottom?
Thanks!!
Thanks!!
