Originally Posted By: Scimmia
Originally Posted By: Gary Allan
Laugh away
I didn't see (though it surely could have been there) what the code was (as in meaning) and I didn't bother to look it up.
..but..as I said in my laughable post, the EVAP PURGE protocol may not occur if the tank is full or close to empty.
No MIL/CEL ...badge.
I didn't mean to laugh at anyone specifically, just the phenomenon of people jumping straight to a leak with any EVAP problem at all, even when it has nothing to do with a leak. I did have to look up the exact definition, but to be fair, I spent a while troubleshooting a P0446 on a Yukon a while back, so I knew right away it wasn't a leak problem. As I said, I don't know Toyota's setup, but in that case, it was a clogged vent canister that was so bad, it backed up and clogged some of the lines.
Some GM engineer should be fired for putting the canister on top of the rear axle on a vehicle very probably would see time on gravel/dirt roads.
Well ...you can wonder if there's Pb in the water at times. Lots of possible reasons in the Too Much Information Age.
