Parts-Mall PBA-001 Kia / Hyundai K5 2.0 L4NA/G4NU
Bulgaria
Bad quality oil filter from Brand: Parts-Mall
Made in Korea
Filter media caps fell off when i tried to remove from the can.
Honestly, filter doesn't look bad to me. Once it's in canister, probably not a big deal about endcaps. My .02.
OEM's are like $4 if you buy a 10 pack. That's what I use mostly, but have a few Premium Guard filters as well for this application. A couple Supertech MP's also (got those free.)
Thanks for the c&p. Almost appears the end caps are just sitting on the glue by design. Would be interesting to check others. Either way I’d prefer my end caps firmly in place.
Similar to some Purolators that are "end cap poppers". The ends of the media cartridge are potted into the end caps, but sometimes it doesn't adhere well to the metal, or it loses bond strength from the use environment. The coil spring should hold the guts tight enough to keep the end caps tight against the cartridge.
Could be better but I run some that have popped ends and don't worry about it since it's only coming apart due to c&p. Never heard of this brand so pass for me.
Service was 5000 miles or 8000 km
previous oil Valvoline 5w40 All Climate/EU version/
Next oil 5W30, with the same brand Filter
The filter will be change in few days with another brand.
There are a lot of glue from the backside of filter. The glue fell apart in tiny pieces.
Today i changed the filter and cut it again
This one it wasn't that bad, bud they're a lot of glue, thin and hard filter media. Also very hard return back valve (rubber).
No metal parts in the filter
