- Joined
- Aug 10, 2024
- Messages
- 14
About three months ago I started an ongoing maintenance interval testing program for my Focus RS. I am trying to determine the actual OCI for this vehicle.
Part one is available here, with all the background on this car. It’s a 2.3 GTDI car, conservatively tuned, used for daily driving in the city, with about 12-14 autocross events and the occasional track day per year.
I decided to do the next testing at 7k instead of 8k, as I initially planned. The goal here is to keep running the oil and testing it until the tests say change it, and then I’ll know what the actual interval is.
I was honestly concerned the oil wouldn’t make it and I’d be hurting the car. But it seems to be doing ok. 3k miles and nothing has really changed except for a couple things as noted below.
Gas dilution is up. As expected. Boron keeps going down as the additive package gets used up. Seems like the shearing out of spec has stabilized, as has the base number. Maybe this engine’s physical design contributes to the initial shearing? 5w50 is an unusual spec for a 2.3l 4 cyl., but it is putting out 400 hp/trq and peak boost around 23 lbs. The owners manual says change the oil after every track day, so maybe the shearing is expected and the heavy weight is for surviving the heat and shear on a track day. This engine does get very hot when you push it.
I used Boostane (very controversial, I know) only for two autocross events. It’s an MMT based octane booster. I was getting some negative corrections during autocross, and I decided to run some octane booster to see if it was false knock from debris on course/exhaust set up or actual knock. That’s where the manganese is from in the sample.
Would like to get your thoughts on whether I should keep the experiment going or change the oil. Only one autocross event left for the season, then it’s shut down to be a daily driver only until next March. At that point it will be 13 months since its last change.
Edit -typos
Edit -typos
