Looks like ToyoDIY doesn't have wiring diagrams anymore, or I'm just not finding them. Do you have a source for electrical diagrams for your car?It is a 2015 4Runner Trail. Bone stock except for tires and shocks. Thanks!
I'll try disconnecting the alternator tonight.Disconnect the Alternator and see what happens to your draw. Could be a defective diode in Alt.. Outside of that make sure ALL the door latches are actually sending closed signals.
In theory yes, light will go out. Lack of a wiring diagram, and experience with stupid designs and electrical wizardry, it's possible that there can be two circuits for those latches. One to turn off light and one to send signal to ECU for safety reasons. (some hood latches won't let car start, and also not connected to a light)I'll try disconnecting the alternator tonight.
Since when I close the doors the dome lights go out, I was assuming that the door switches are good. Would this be correct? Thanks..
Pay the $20 and get 2 days on TIS.I’m having no luck finding a wiring diagram.
What does the security system look like on that thing. Does it show its active in the dash when locked (my nissans show a key, and I think our Rav has a flashing light. A bad door switch possibly is not allowing the security system to enable or something.I'll try disconnecting the alternator tonight.
That's a really sharp idea!Put a charger / tender on the battery and then in the morning, when it's cool, scan the wiring / ECMs / relays with a thermal camera. 500mA @ 12VDC is about 6 Watts of heat going somewhere.
Thanks for taking the time to do this.!Here are some diagrams, I highlighted the relevant circuits, it appears there is a large junction block behind the gauge cluster that may help in halving the circuit for testing.
Never had alarm or tracker on any of my new vehicles. I don't pay for those options. Remote start is included.Aftermarket alarm/tracker/remote start? Even if not activated many dealers install this trash.
