N Ndx Joined Apr 4, 2008 Messages 1,938 Location IL May 6, 2022 #21 I successfully used tool similar to the second one ( ratcheting spreader ) on Brembos on P brand car. Lang is the brand of tool, good price and made in USA
zzyzzx Joined May 18, 2012 Messages 12,691 Location Baltimore, Maryland, USA May 11, 2022 #22 Hall said: A semi-popular mechanic on YouTube uses that ratcheting, spreader type and seems to really like it. Click to expand... Rainman Ray, I assume. If you can't easily push the caliper back in with just a C clamp, consider that you might have other issues.
RooflessVW Joined Dec 24, 2011 Messages 16,072 Location North Carolina May 11, 2022 #23 zzyzzx said: Rainman Ray, I assume. If you can't easily push the caliper back in with just a C clamp, consider that you might have other issues. Click to expand... Like having a fixed-piaton caliper?
zzyzzx Joined May 18, 2012 Messages 12,691 Location Baltimore, Maryland, USA May 12, 2022 #24 I meant if you can't easily push the piston back in, then consider the possibility that there are other issues (like a caliper clogged with sediment or brake hose issue). I got my terminology wrong above.
