hey everybody..I have noticed on my 07 mitsu endeavor that the idle was very rough..The check engine light came on and I got a P0306 code from an actron scanner..The code indicates a cylinder 6 misfire..I took the plug out and the tip of the plug had oil on it..i asked a mechanic and he told me that its probably a bad valve seal..Im bringing it in to get serviced over the weekend.Ive been running 5w20 full synthetic( PP, Valvo synpower) in the truck since about 45k..the truck now has 70k on it..the oil is due for a change and I dont know if i should stick with the 5w20 full syn or go with a 5w20 synthetic blend.. Any and all suggestions would be a great help since this is the place to ask a motor oil question..
I do oil changes about every 5 to 5500 miles..The truck sees mostly stop/go but gets some highway use also..I live in NYC area..thanks for the help
