Originally Posted by CKN
Originally Posted by 02SE
P-rated tires when mounted on Trucks, SUV's or Vans, have their load rating reduced by a factor of 1.1. Which puts you at less load capacity than your LT tire example.
The tires equipped with the vehicle when new must met the specs (towing, payload) of the said vehicle when new. It should be noted MOST half-tons come equipped with "P" rated tires.
I'm well aware of that.
However, lots of people aren't aware that P-rated tires have a reduced load capacity (by a factor of 1.1) when used on trucks, vans, and SUV's.
In the OP's case, the P-rated tires he's considering, have LESS load capacity than the LT tires he mentioned, in HIS application.
