JHZR2
Staff member
Hi,
My mother's 97 plymouth breeze has stated that it wants a new O2 sensor.
The car gave me the codes by switching it on and off a certain way, and counting blinks.
The code referred to oxygen sensor malfunction or voltage not fluctuating.
My issue is, there are two: one pre cat and one post cat. From what Ive researched, the post cat one is more or less useless, and only there to verify that the converter is working.
I will change the front sensor. However, I have a bit of logic and wonder if I am on the right track:
If the rear sensor verifies catalyst operation, if it was the bad sensor, I would get the oxygen sensor code, AND a code relating to a malfunctioning catalytic converter. Or, I might only get a code relating to a bad converter.
On this logic, I assume that it is only the front sensor. Make sense?
Of course it is easy enough to swap the main one, and if the light continues, to then replace the rear one at a later time. But it would be nice to have an idea, and based upon this idea, potentially save an extra trip to the parts counter...
So, what is yout thought? Front or both sensors? I dont mind spending the extra $100 if its best for the car, but I believe that it may be a useless swap unless it isnt working, since it does not apparently effect anything.
Thanks,
JMH
Thanks,
JMH
