Carlostrece $100 Site Donor 2025 Joined Mar 26, 2017 Messages 915 Location NW Oregon & SW Washington May 19, 2025 #1 Which attributes on a motor oil data/spec sheet indicate: Resistance to oxidation Amount of seal conditioner
J Jetronic Joined Feb 27, 2009 Messages 11,549 Location down in the park May 19, 2025 #3 Carlostrece said: Which attributes on a motor oil data/spec sheet indicate: Resistance to oxidation Amount of seal conditioner Click to expand... Nothing on a typical datasheet, but... Anti - oxidants like ZDDP or MoDTP
Carlostrece $100 Site Donor 2025 Thread starter Joined Mar 26, 2017 Messages 915 Location NW Oregon & SW Washington May 19, 2025 #4 I know noack refers to evaporative loss, but does noack also tell anything about oxidation?
MolaKule Staff member Joined Jun 5, 2002 Messages 25,102 Location Iowegia - USA May 19, 2025 #5 Carlostrece said: Which attributes on a motor oil data/spec sheet indicate: Resistance to oxidation Amount of seal conditioner Click to expand... None. What you see in a TDS is a listing of the Oil Properties.
MolaKule Staff member Joined Jun 5, 2002 Messages 25,102 Location Iowegia - USA May 19, 2025 #6 Carlostrece said: I know noack refers to evaporative loss, but does noack also tell anything about oxidation? Click to expand... No. What you see in a TDS is a listing of the Oil Properties. See the Bitog Glossary: https://bobistheoilguy.com/glossary/ Last edited: May 19, 2025
Carlostrece $100 Site Donor 2025 Thread starter Joined Mar 26, 2017 Messages 915 Location NW Oregon & SW Washington May 26, 2025 #7 I looked in the glossary and acronyms threads. I did not see TDS in either. What does TDS mean? I assume it means manufaturer's oil Data Sheet, but what does the T mean?
OilStainedNapkin Joined Aug 15, 2024 Messages 468 May 26, 2025 #8 Carlostrece said: I looked in the glossary and acronyms threads. I did not see TDS in either. What does TDS mean? I assume it means manufaturer's oil Data Sheet, but what does the T mean? Click to expand... technical data sheet
