No ..I'm sure that there's a bigger one. It may have a different bypass valve setting than the various normal offerings ..but I'm sure that there's one out there. It's been mentioned several times in my history here.
That is, it's not like a PH8A/PH16 comparison ..but it's gasket/thread compatible. In a reverse view, the FL820S is a big version for GM engines (I think).
Part Number: 57060
Principal Application: Various GM Vehicles (07), Corvette (06-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/75=10/25
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.410 0.270
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-07), Mazda (00-07), Cadillac STS-V, XLR-V (06-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.660
By-Pass Valve Setting-PSI: 12-15
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Gasket Diameters
Attached 2.834 2.462 0.200
