Parts replaced, in order, to alleviate overheating issues:
1) Radiator, fall 2009
2) Water Pump, spring 2010
3) Radiator again, spring 2010 (cracked when water pump failed)
4) Upper and Lower hoses and clamps, spring 2010
5) Heater hoses and clamps, spring 2010
6) Radiator cap and line to burp tank, summer 2010
7) Bypassed leaking heater core, spring 2011
8) Thermal fan clutch, summer 2011
9) Electric fan, summer 2011
System has been pressure tested and holds 19lbs just fine. Heater core function shouldn't be required to maintain cooling system integrity and performance. So where I'm at is the truck runs great with the AC off at any time. With the AC on, in 95+ degree heat, in traffic or at low speeds, the truck will go above 210 degrees. Electric fan is now working properly, it comes on just below 210 and stays on. Rear AC gets nice and cold but front AC gets hotter as the engine heats up. This should have been eliminated when the heater core was bypassed. Now I'm not so sure.
If I keep driving it'll settle just above 210 and stay there. Turn it off it goes halfway to 260 when you restart and it'll come back down to just above 210 and stay there. The AC won't blow cold again up front until it drops below 210 and that takes 6 to 10 miles of highway cruising above 50mph. As soon as you get off the highway it heats up again.
My theories:
A) The engine has a slightly blown intake or cylinder head gasket and combustion gases are heating up the cooling system.
B) The radiator that was installed is a cheap piece of garbage and is probably one row and not up to the task of a V8 truck with front/rear AC in 100 degree Texas weather.
C) The condenser is clogged up with dead bug guts and that's making it inefficient and it needs cleaned or replaced.
D) The cooling passages in the engine are clogged up somehow that the flush in spring 2011 didn't git 'r done.
Any other ideas? This is our primary vehicle and really I just need it to survive a few more months for my wife to trade it off on a new Explorer (or Durango or Acadia or Pathfinder or 4Runner or whatever she likes best when the time comes to blow $30K on a new truck).
My theories:
