Overfilling the differential
JHZR2
Staff member
New Jersey
Hi,
Are there any issues with overfilling the differential of a car? When I opened the fill plug on mine, a LOT of fluid gushed out. The diff was warm, but not hot to the touch.
Will overfilled diffs cause extra noise?
Thanks,
JMH
Is that a rear axle diff? A seperate but joined transaxle diff can fill with the fluid in the gearbox.
I had a boss that used to overfill heavyduty equipment diffs by putting a rag over the hole while filling it. Then he'd quickly put in the plug. It's probably not good for mileage but he was quite smart.
Steve
Rear differential units generally have a lot of air space, and a vent.
A little overfilling won't make a harmful difference.
The fluid and gears expand quite a lot when even moderately warm.
I overfill mine just a tad by parking the vehicle a few inches up on ramps when filling. I fill just enough for it to run out when the check plug is removed on level ground.
No problems here.
I also use JAYCEE's method. Overfilling will cause extra foaming to occur. Let the excess run out on level ground.
