Outboard: 2006 Yamaha 15 HP 4-Stroke
NY
I am presently using 10w30 Yamalube in my outboard. I am considering switching to Royal Purple 10w30 and 75W-90 Royal Purple for the Lower Unit. My goal is to increase the HP a little while reducing wear and tear on the engine. I am to follow the manual and change the oil each season or after 100 hours of use. Am I making the right decision?
Thanks,
AF
I put many hundreds of hours over 10 years on a Yamaha 9.9 hp 4-stroke in saltwater under very heavy use using nothing but whatever oil I could get cheapest, but then I eventually did switch to Amsoil 4-stroke stuff. I will say the engine ran noticeably smoother with the Amsoil, but there was no detectable change in performance. Hard to say if the Amsoil would have improved durability as my engine was suffering from saltwater corrosion when I sold it. Engine still ran and worked perfectly though. Today I think I would go for one of the HDEO oils like Rotella. Again, lower unit I used cheap stuff, but I did have to have it rebuilt after the seal was destroyed by some fishing line. The 15 HP, which is nearly the same as the 9.9 HP, is extremely durable whatever oil you use.
Just make sure you use a good fuel filter. I installed a Mercury spin-on type (looks just like an oil filter) and ran all gas through it. Made a world of difference in preventing carburetor clogs. The passages in those carbs are so tiny that the most miniscule piece of crud will plug up the low-speed jet. Also, add StaBil to all your gas.
Originally Posted By: Bluestream
Stay with the Yamalube. how many hours are you running per year?RP will not increase hp.
80-100 A year. What about using synthetic in the lower unit?
I do not think there is as much difference in oils as most people imagine there is. If the oil meets the specs it is good. You never will gain a noticeable amount of horsepower with any oil all things equal. Shell Rotella T5 10w30 is probably a way better oil, and costs less as well
