Since I own a Chrysler product I have been trying to figure out why some Chrysler models have standard/copper spark plugs as OE from the factory. I could understand my Jeep Patriot came with standard/copper plugs because it's a cheap car. But Dodge Ram Hemi uses the same style standard/copper plug. That is not a cheap car. Ram owners should not have to change plugs every 30,000 - 40,000 miles.
My co-worker owned a Suzuki SX4 that came with OE Irdium spark plugs. This is also a cheap car. He changed them @ 180,000 miles. Spark plug gap was still within spec.
Here is the best info I've found on Irdium Spark plugs:
"WILL AN IRIDIUM SPARK PLUG BE BENEFICIAL FOR MY PARTICULAR ENGINE?
This is very subjective. The vast majority of vehicles/engines will benefit from replacing a standard spark plug with an Iridium spark plug.
Most benefit will result if:
There is a very close Iridium spark plug match for your standard spark plug (i.e. overall design is very similar)
The standard spark plug you are replacing is a basic copper plug (the Iridium plug will then be a more significant upgrade)
The engine has a large cylinder capacity and a large number of cylinders
Least benefit will be realized if:
There is no close match for your standard spark plug, it isn't worth compromising plug design purely to use an Iridium plug type.
The standard plugs are already a performance or enhanced design. Some standard (Original Equipment) plugs are Iridium or fine wire platinum types, these may already provide the ultimate performance and service life for your particular engine. Fitting an aftermarket Iridium plug may actually result in a drop in performance and service life."
from: http://www.sparkplugs.co.uk/iridium-spark-plugs
Do you think Chrysler uses standard/copper spark plugs in new vehicles just to save money? And to make dealers service departments more money?
Well, you know, they can do that if they want to. Chrysler has had some very nice looking models to compliment cheap models like Patriot, Compass and Caliber.
