Interesting. Yeah I ran down to autozone at 7:45pm after calling to verify they were in stock and had them installed an hour later after eating dinner. Spark plugs sure are expensive these days. Used to be $2.50 ea now they're like $10 eaIf you buy iridium plugs from amazon or ebay there's a better than not chance they are counterfeit. Avoid for plugs. Rockauto or real auto shops
Wonder why they would make fake spark plugs of all thingsIf you've bought NGK S/P out of eBay or some unreputable source, then you more likely bought a fake plug
Didn't they start making spark plugs designed to make it to 100k? I don't think these iridiums plugs are very good. Had the same issue on the boat that I had on the side by side. Stumbling at lower rpm, nor firing on a certain cylinder. New plugs fixed it
I really like the Denso Iridium TT plugs, they are just a hair over $5 per plug on rockauto. I would put them up there with the OEM NGK iridium's in a lot of cars.Interesting. Yeah I ran down to autozone at 7:45pm after calling to verify they were in stock and had them installed an hour later after eating dinner. Spark plugs sure are expensive these days. Used to be $2.50 ea now they're like $10 ea
I mean it's mostly covered by the bootBoats run pig rich when cold. Also any water splashed on the hot ceramic body and cause a micro crack. Find out why they failed, there IS a reason.
$$$$Wonder why they would make fake spark plugs of all things
Depends on the engine and driving habits. I have cars that eat iridium in 15k. Others that can do 60k.Didn't they start making spark plugs designed to make it to 100k? I don't think these iridiums plugs are very good. Had the same issue on the boat that I had on the side by side. Stumbling at lower rpm, nor firing on a certain cylinder. New plugs fixed it
What do you do with the ones that wear out at 15k?Depends on the engine and driving habits. I have cars that eat iridium in 15k. Others that can do 60k.
Garbage can.What do you do with the ones that wear out at 15k?
I meant how is the vehicle operated causing them to wear out so soon.Garbage can.
Turbo engines, hard driving and some blow-by.I meant how is the vehicle operated causing them to wear out so soon.
Oh, so it's older and somewhat worn out?Turbo engines, hard driving and some blow-by.
One engine is older. Another that kills them is very fresh, but sees a lot of wot.Oh, so it's older and somewhat worn out?
