I read with great interest the writings of Dr Haas.
If one wanted to follow his methods, then am I right that I need to do the following
1) Find out the recommended psi for my engine
2) Find these out for a range of rpms
3) Fit an oil pressure gauge after the filter
4) Run the thinnest oil I can that keeps oil pressure at the recommended psi
If so, where can I find these recommended psis and does anybody have any tips for a good oil pressure gauge and how to fit it.
Lastly, if this logic is the best way to maintain your engine, then it would be great if cars could automatically recommend what oil to use.
What I mean by this is if there is already an oil pressure sensor in your car, then presumably the computer could record the oil pressure at different rpms (may need to upgrade the sensor). It could report back to you whether you were within optimum parameters and whether or not you should go with a heavier or lighter oil (presuming the goal is to maintain the right oil pressure).
Btw, why is the goal to maintain the right oil pressure? If flow = lubrication and higher flow lubricates the best, wouldn't the goal be to maximize flow and therefore minimize pressure?
