Id keep LFP at 100 unless Tesla says otherwise?That involves more thought. I just don't bother worrying about it much. I could set a limit and just keep it plugged in but considering that the LFP has such a narrow voltage range I like to occasionally let it drop down and Tesla says to charge it to 100% once a week. It's the only way I'll accomplish that for battery management anyway. Sure it only seems to use the power supply to warm up when it's plugged in and if I have a longer trip to make then I worry about it. Most days the car doesn't see more than 10 miles so I don't worry about it. I'm only using 120V right now so everything is a trickle.
I have all the temperature protections shut off. I'd worry about turning those on if it was sitting out in the elements when it's cold, but the car heats up quick enough that I just don't concern myself with it and and it's been especially mild this year.
When I start daily driving it in a few years my tactics will definitely change. I'll use the battery limiter and then allow it to get to 100% on 240V when I get called to work. It's the right battery to deal with my style of abuse moreso than the ones that say to limit charging to 80%. If I do that I'd get roughly the same range as the one charged to 80%. That's a better fit for my wife's usage. She really wants a Model X so I'll likely buy one of those used in a few years and drive our current car daily.
