OVERKILL
$100 Site Donor 2021
Originally Posted By: HangFire
Originally Posted By: dparm
The problem with this is all it takes is one idiot to accidentally plug a wire from an AP into the office network for that separation to be broken.
The moment that cable is plugged in, a VLAN mismatch is detected and that port is shut off.
Unless your IT department is a bunch of rubes using unmanaged networks or something.
Some of the stuff I've seen in hospitals, particularly small and old ones, would make your eyes pop. Picture somebody with their own Apple Airport plugged into some unmanaged D-Link switch they bought at BestBuy under their desk with half their office plugged into it
This stuff happens, and probably more frequently than you'd think.
I've pulled the same garbage (minus the airport) out from behind desks that was put there by the IT department because they didn't have enough drops in the office and so they just tossed some garbage switch in there to "make it work". You can be quite sure there was no MAC filtering or VLAN checking going on there
