Something been bugging me for a while. A few days ago, I changed the oil on a friend's Silverado with the 6.0L. Filled it with Peak 5w30 and used a Napa Silver oil filter (Part number SFL 31042). I took off the oil Champ filter, lube the new Napa filter, pre-fill it and screw it on. After the gasket touch the base, I marked the filter and began to tighten the it to the spec, 3/4 turn. However was only able to get 1/2 a turn. I clean the oil filter and grab a clean towel to try to turn it another 1/4 turn out it would not budge.
I finish filling the engine and ran it with no leaks. I was still uncomfortable with 1/2 turn so after cooling the engine. I remove the filter to check that the gasket was seating in the groove of the filter. I clean the filter housing and the filter can, lube the gasket and re-installed it. After the gasket touch the housing, I began to tighten it and it stop at 1/2 turn. I tried to muscle the last quarter turn but couldn't. Top off the 1/2 qt spill from the filter and ran the engine to check for leaks, none.
I'm bother by the fact that I couldn't turn this oil filter to the full 3/4 turn. I was able to turn every oil filter to spec before by hand. I just worry that the filter may back off or something. Should I lose sleep over this? (which I am posting this at 3am, lol) Or is it fine as long as it was tight.
