Gator, what you're suggesting will work fine, but I'm not sure about your numbers. Why not work out a scheme for every 2000 miles or 3000 or whatever works for you, that over, say, 100,000 miles uses the same number of gallons of oil and same number of filters. But, why bother? If you were talking about an engine in an industrial use where you could not shut it down, yes, tap a little off regularly and add a little, and it'll be fine. For automotive use, why not run the full manufacturer's oil drain recommendation? If you have any doubts, run a few lab tests of the oil. The tests will cost a lot less in the long run that throwing away good oil on guesswork.
