Product Data Sheet: HPSGlide
High Performance Synthetic Power Steering Fluid
HPSGlide is recommended as a replacement for most power steering fluid systems except Honda. HPSGlide combines the best in additive technology and synthetic base oils to provide a robust, all temperature Power Steering Fluid.
HPSGlide quiets noise in most power steering pumps while reducing leaks. Anti-Wear agents reduce power steering pump and rack wear. Cleaners and dispersants guard against particulates that build up on valves and pistons.
This lubricant fluid has a low pour point for cold weather driveability, and possesses excellent high temperature stability against oxidation and shearing (viscosity loss) at high temperatures. Inhibitors prevent rust and varnish buildup. Friction modifiers reduce power requirements at all temperatures.
Note: Do NOT use in Honda power steering systems.
Directions: Tighten or replace power steering belt and make sure belt has no cracks on underside that might cause slipping or loss of Steering System control. Replace old fluid by repeatedly using a Turkey Baster until fluid is clean, or remove low pressure hose and let drain. Replace hose, tighten clamp and then refill reservoir. Do not add any aftermarket additives to this fluid.
Properties (Typical)
Viscosity @ 100 C 9.0 cSt ISO 46/68
Viscosity @ 40 C 52 cSt
Viscosity Index 168
Flash Point 423 0F
Fire Point 460 0F
Pour Point - 48 0F
Noack Volativity 2.19% (ASTM D-5800)
TAN 0.5
TBN 2.1
Color Clear Red
Note: Not for use in Automatic transmissions, manual transmissions, or engines. May be used in hydraulic systems requiring an ISO 46/68 fluid.
Order Code: HPS-PSF
Specialty Formulations is not responsible for misuse of this product. Wash hands after use. Keep out of reach of children.
