Old Gas
Connecticut
I am sure this has been covered before and I did some searching but lots of opinions and little science.
I am quite familiar (I am sure most BTOG regulars are) with the general problems associated with old gas - evaporation of additives, Ethanol/water separation, particulates, varnish, etc.
What I am really after is... what is left after old fuel has been filtered and free of water? I know it still burns. In fact, I think it has more volatile characteristics when tossing small amounts on a bonfire. Could that be due to the lack of octane?
If you are interested in the reason I am asking... I finally sold my old boat last spring, but before I did, I pumped the 30 gal or so of fuel that was in the tank into a portable tank (with wheels kind-of thing). Now I have to figure out how to get rid of this 4 + yr old gas.
My plan is to filter the gas, add some octane booster, mix with 50/50 fresh 93 octane gas, and run it in my old Chevy blazer plow truck (with a marine 350 and an Edelbrock carb). The Blazer also has a marine spin on fuel filter in the engine bay - I think 10 micron. The Blazer does not come out of low range and rarely sees over 1500 RPM, although it will see some torque loads if plowing.
At $4.29 / gal for premium in the great state of Connecticut, I would like to reduce the fresh fuel ratio even further, but not sure if that is a good idea.
Thanks for all your help!
clint
Old gas lost most of it's volatile "aromatic" part of the gasoline (aka "essence" ) and whatever remains are primarily varnish ---things that don't burn or just barely burn but leaves a lot of carboneasous soot.
Since the decomposition of gaoline will eventually turn into varnish-like stuff(and gas goes rancid), it's a one-way (directional-wise) affair and no known means to reverse the process.
I know no additives out there (including the ever-so-famous, aggressively worded PRx-G product) that can reverse this process.
Sorry but the proper way is to find a facility to dispose of these old gasoline safely and in an environmentally-sensible manner.
Q.
p.s. I won't even risk ruining my car (injectors, carbons inside my combustion chambers, killing my O2 sensors, etc.) by mixing it with fresh gas + whatever have you additives and try to get something out of it.
I have 35 gallons of old (from March 2013) pre-mix 2-stroke gasoline from my boat. This gas has been stored in 6 gallon plastic cans and stored inside a covered boat all summer.
I'm just gonna funnel this gas into my truck. Shouldn't hurt a thing. But I'd never put it in anything I really was dependent upon, or any vehicle that's too nice.
About two weeks back we were tidying things for the Fall and the wife asked what to do with the left over, (from the summer)ride on lawnmower gas. I told her to pour it into my Truck (a Carbed Toyota 22R) after she did that, she remarked how bad that gas smelled.
It turned out 'that Gas' was what I had drained out of an old Outboard motor tank (2 stroke) about 6 years ago!
The smell was overpoweringly sickly.
The old gas added to the truck accounted for about 60% of what was in the trucks tank. But the truck started and ran perfectly fine.
It was about three days before I got around the Fulling the truck with fresh gas, but I had no problems in the meantime running the old stuff.
BTW, there is no cat on the truck.
You guys can do what you want with that old/bad gas. After being in the business for as long as I have, and fixing many thousands of engines that have suffered problems from it, I would NEVER use any of it in ANY machine that I own, and I have access to hundreds of gallons of the worthless stuff every year.
If you use it in your car/truck you might get lucky and not have a problem with it. But, you might gum-up your fuel injectors, stick your intake valves open (and on an interference engine, destroy the engine), ruin your fuel pump and/or a couple of O2 sensors, etc, etc! Is it worth the risk? Not in my car it isn't!
What do you get when you mix 5 gallons of old/bad gas with 5 gallons of new/fresh gas?
10 gallons of BAD gas!
Thirty gallons of fuel is like a light snack to an old carbed SBC truck.
I'd run maybe a couple of gallons at a time in a full tank of fresh gas.
You'll certainly go through all of it over the course of the winter at that rate.
A little at a time shouldn't cause any harm at all.
