JHZR2
Staff member
Went to do some mowing this evening, and my old Snapper 3.5 Max fired right up. Maybe two minutes in, I heard a shreaking sound. Horrible noise. I stopped the mower, tried to start it, and found that the recoil wasn’t working.
Pulled it apart and…
How does that happen?!?
Pulled the shroud, seemed ok, maybe the recoil unit jammed?
Spring was not working right. Not sure why. Wasted way more time than I care to admit tonight figuring out how to rewind a clock spring and set it up…
I put a little HPL on the oil pad hole in the ratchet start assembly. Didn’t lube up the ball bearings but they alll looked clean and fine.
So, what caused this, and how do I prevent it? Definitely wasted my evening…
