We have a large okuma lathe at my job. It has two turrets in it. We are having an issue with the sensor that allows the turret to index around. The sensor is the type where when you bring a piece of metal close it activates. It has 3 wires. Power, ground, signal. It gets 24v on the power wire and 24v goes out the signal wire when the switch is activated. The issue is the new switches installed keep going bad every day within 10-20 hours after installation. Maintenance is not sure what the issue is and we will need to get an okuma tech out. Are there any suggestions of reasons the switch keeps going bad?
