Hi everyone, I'm new to BITOG and I've just read the first sticky post. I wanted to probe the community's input on whether it's a good time or a good idea to start using synthetic oil (specifically Pennzoil Platinum 10W-30) in my car.
Let me explain. I have a 1993 Toyota Corolla station wagon with a 5spd manual that's about to pass its 180k mile mark. I'd like to keep the car as long as it will last, as I haven't found any other economy car that I enjoy driving on a daily basis as much as this one.
For its whole life the car has used regular "toyota genuine" (mobil) dino oil, changed faithfully every 5000 miles as per the manual's recommendation. As it neared 180k miles, some problems began to develop. It burned about a quart of oil every thousand miles and puffed blue smoke out of the exhaust every morning. For this reason I decided it was a good idea, at the time, to stick with the oil I was using. I didn't want synthetic to uncover any leaks or burn more rapidly.
Before it hit 180k miles, I wanted to take it to my mechanic so he could do some major services that were due. In addition to doing manual-specified maintenance, like installing a new timing belt and doing a valve adjustment, my mechanic tried to fix the oil-burning problem by replacing all of the oil seals, including the valve stem seals. In the end, the service was very extensive, and you can see the whole list of parts replaced at this link.
After I got the car back from my mechanic, it dawned on me that since I have had basically all of my seals and gaskets replaced, I can probably start using synthetic oil without worrying about any leaks appearing. My main reason for wanting to switch to synthetic would be to increase the life of the car and decrease engine wear. I don't really car about lengthening the oil change interval.
I'll go through the standard gamut of questions. My Corolla takes 5w-30 in the winter and 10w-30 in the summer. I live in sunny California and give it 10w-30 year-round. I often take my Corolla on many short trips throughout the week. Basically, I start it from a cold start, drive it 4-10 miles, and let it cool down again. I understand this type of driving wears engines down pretty heavily, so I follow the car's recommended "severe driving" maintenance schedule. I'm also very gentle with the gas and shift at low revs while I'm driving.
Given everything I've explained, do you think now is the time to make the switch to synthetic oil, given that I have all new seals, or should I stick with what's been good for the car for the last 20 years? All I want to do is enjoy the car that I've enjoyed driving daily for as long as possible. I'd appreciate any input and I thank you for your time.
asme
asme
