I have an 07 Silverado Classic "LBZ" Duramax with 48k miles on the ticker now. Bought it when it had 20k and switched to Mobil 1 Turbo Diesel Truck 5w-40 oil. Ran it for 10k miles, was about 3 quarts low even though this is in spec for oil consumption on these engines and had high copper count "oil cooler". At 30k did another Mobil 1 Turbo Diesel Truck oil change, and ran it 10k miles same as first.. with same analysis and consumption results. At 40k I filled with Rotella T6 5w-40 and now at 48k it is getting close to the 3qt low just like the previous consumption pattern. Sooo.. my thoughts on the change coming up soon would be to fill with 5 quarts T5 15w40 conventional and 5 quarts T6 5w-40 synthetic.. would this make something like a 10w-40 blend? I'm thinking a little thicker mix might help reduce consumption, add a little extra oil pressure and help my centrifuge work better
What are your thoughts?
