Hi everyone, I have an 02 Honda S2000 which uses Oil jets at the bottom of the crankcase to spray oil under the pistons for extra cooling and lubrication. Apparently Honda changed the design of the jets as some vehicles exhibited oil related failures under hard driving conditions. My car is listed as not having the upgraded oil jet design, probably missing the part changeover VIN list by a few hundred vehicles. I've read that the upgraded oil jets have 4 holes instead of 2 holes, and the holes are smaller in size. I would think they would flow more oil and at higher pressure if the description of the design upgrade was correct.
I question the effect of a thicker oil viscosity on the spray patterns of oil jets. Honda lists a 10w30 oil and a 5w-40 viscosity that is suitable for our engine. I have made the choice to run the 5w-40 visc in Amsoil brand, I bought the oil and I won't change my mind on that. But I'm curious what people think about this viscosity and the spray pattern of oil jets. I would think the engine would have slightly higher oil pressure, which might exhibit a more forceful spray of oil out of the jets. Perhaps this may make up for the upgraded oil jet design that my car didn't get ?. Any opinions on this would be interesting. thanks for any replies.
