Engine: Dodge 2.4L Turbo Charged 4 Cylinder
Coolant temps: 195-212degrees
oil pressure: 25psi at idle, 35psi at 3000 rpm
Oil used: AMSOIL Signature Series - 5 quart sump
The turbo is oil/coolant cooled and there is an oil cooler that has coolant lines going to it also.
I just installed an oil temperature qauge today, and the sensor is in the oil pan. I went for a 20 mile cruise down the freeway at 70mph just get a reading, which was 190-195 degrees. I then went for a short "spirited" run up in the hills to see how fast it would rise. in less than 3 miles I had it to around 210 degrees and it pretty much stayed there. I didnt push it too hard because it started to rain.
My question is, how cold is too cold for oil temps? I would also like to know what temps would be to high for when I hit the roadcourse?
how would changing oil weights affect oil temps?
If you need anymore info, let me know.
