Originally Posted By: mechtech2
99GASE2 -
Climate makes a HUGE difference in oil temps.
How can you say otherwise?
This is a generalization, and is NOT correct for ALL cars.
My VQ runs the same oil temps summer and winter (and these are Canadian winters) no matter what. My oil takes only a few minutes longer to warm up in the winter than in the summer. Insignificant.
In the summer, my oil will be up to 220 F in less than 10 minutes, and will be at the same temp in the winter in about 15 min. If I don't use the highway at all in the winter, the temp is about 10 degrees cooler (~210). This is measured as the oil comes out of the sump and gets pumped to the oil filter.
As you can see by this example, it is not correct to generalize. You need to strictly speak about a certain car with a certain engine, as many of them are quite different from each other.
My brother's Vibe on the other hand... It can't even heat it's coolant up in the winter let alone the oil...
99GASE2 -
