I'm running a fairly high strung Ford Windsor stroker that has had Valvoline 20w-50 full synthetic most of its life. My running oil temps are in the 212-220F range and the car has a front-mounted, thermostatically controlled oil cooler and remote filter. Idle oil pressure is 38-39 and running psi is mid 50's.
What oil advice can one give to reduce my oil temps to the 180 range? Straight conventional oil? Thinner viscosity will (most likely) lower my idle and operating pressures, accordingly. I realize I need FLOW to keep the bearings cooler, but not at the expense of shear. Where's a good place to start?
Thanks,
-DH
Thanks,
-DH
