oil temp probe
Detroit, MI
I wanted to add a oil temp guage on my boat's engine. It already has an oil pressure gauge, and I was wondering if it is ok to install a t-fitting where the oil pressure sender is and simply add the temp gauge, or if oil temp should really be read from the pan??
I was just wondering, because as far as I know, for measuring transmission temp, it is best to have the sensor in the pan and not in the line to the cooler. In the pan it is the sum of the temps, where as on the hot side line, it's hot, and on the cool side line, well, its cool. So, I was just trying to get some ideas. I've seen some temp senders that actually replaced your oil drain plug..
Adding it on a T is not going to give the best readings because there isn't a lot of flow through a T. Directly in the passage would be good. A sender in the sump would be a better choice if that's your only other option.
I don't own a boat, but I like the drain plug idea. If you have access to a lathe, you could probably drill & tap the drain plug for the sender (or a machine shop might do it for a small fee). Plus, if things go bad, you're only replacing a drain plug.
