I'm new to the Forum and I hope I'm posting in the correct topic!
I recently read with much interest, Motor Oil 101 by AE Haas.
What I am wanting to know is....
What is the perfect thermostat temp to promote a 212 degree
oil temp?
I'm running a new 383 SBC w/cam & carb, no emissions or sensors. I live in Phoenix AZ. & most of my driving is in 65 to
115 degrees weather. In our cooler weather will a 180 water temp heat the oil enough to burn off the moisture, carbon, etc?
If I run a 195, in the summer I would expect a 220-225 water temp in traffic.
I'm running 10w30 Amsoil Z-rod for my flat tappet cam, with a Mobil 1 filter.
Seems like most Hot Rodders are afraid of 200+ water temps and from what I read I need at least that temp to promote a healthy
engine internally!
Give me some input on this!
Thanks! Joe
oil temp?
engine internally!
Thanks! Joe
