Oil suggestions wanted!
South Dakota
You may recall from previous posts, my 2005 Dodge Grand Caravan was using about 1/2 to 3/4 qt of oil in about 1200 miles (Havoline 5w20). I switched to Motorcraft 5w20, thinking this might help. With 2500 miles, I have used almost a full quart of oil, which comes out to about the same rate as Havoline usage. Is this something that I am going to have to live with or is there hope that I can reduce consumption by a different brand of oil? I was considering Mobil Clean 5000 or Castrol GTX as my next oil choice in hopes to alleviate this problem (which Dodge says is normal).
At this point, I would even consider a low cost synthetic and 7500 OCI's if this would solve the problem and be cost effective.
Any suggestions?
I wouldn't switch to synthetic in an oil burner, but instead move up in viscosity with your conventional oil. Thicker oil will have a harder time getting past the rings or valve seals, whichever is the problem area in your engine. I know this is a completely different engine, but consumption started to go up in my old 2.5 Chevy engine and after I switched it to 20W-50 (summer only) consumption slowed. Try thicker, but don't go overboard if it's cold where you are.
I have the same issue with my 92 Galant SOHC 2.0.
running 5w30 now.
she has a slight tick, so everyone has urged me to go thin.
but she burns oil.
maybe a thick blend like MC 10w30?
in the winter?
running 5w30 now.
but she burns oil.
in the winter?
MC 10w30 is a thick 30 but the 5w30 is just as thick at operating temps. If it were me i'd try a high mileage 5w30 after perhaps an engine flush.
Quote:
Quote:
I would have to agree with the other posters that a 5w30 might do the trick.
been running various 5W30's with no luck
Sorry, that was actually directed towards the OP. For your car i'd still think a high mileage oil, 5w30 or 10w30, after you flush the engine may be your only hope. If that does not help it may take mechanical repair to stop the burn.
Any suggestions?
Valvoline Maxlife Synthetic.
The seals may have a buildup that came from the factory. This oil may improve things. Do two 5-6K OCIs with it & keep us updated.
thanks...the burn isn't too bad, 1-1.5 qts every 3k mile OCI...not much worse than my F150 5.4L LOL.
but the slight tick bothers me...then again, i'm told i'm the only one it bothers
