Originally Posted By: Onug
I'll ask a follow-on question. In theory, if shearing dropped the viscosity down and sludge started to bring it back up, you could run your used oil analysis when the sludge itself puts the oil back into the normal viscosity range. What component of a used oil analysis would you look at to see the sludge?
Can't really see that in a used oil analysis since only certain elements are shown, and oxidized oil (thicker components) are just oxygen on the usual hydrogen and carbon molecules. Indirectly you can tell how much acids have been eating up the buffers by looking to see if the TBN has fallen to less than 2. If its that low, acids have been attacking, and the viscosity may have pushed upward from too much oxidation as additives get destroyed.
