Oil Selection for After Turbo Rebuild
Central NJ
I'm rebuilding my turbo on my 2004 Passat and I was wondering if anyone had any legitimate objections to using Rotella T6 or could recommend a better-suited oil. I know T6 isn't VW 502-spec oil but it appears to hold up well in this application. I also have 5 qts. of Mobil 1 Turbo Diesel Truck 5w40. Any recommendations in general regarding the rebuild? Should I run a cheap dino for 1000 miles to flush any contaminates?
No objection at all! Either Rotella T6 or Mobil 1 Turbo Diesel Truck would be excellent choices for your Passat. If it's just the turbocharger you've renewed, there should be no contaminants to 'flush' out. Use a quality filter & either of the oils you mentioned for 10k miles with confidence.
Ive had great results with Mobil 1 0w-40 in 1.8T engines. RTS is a great oil and Id consider its use, but no reason I can think of not to use 0w-40 Mobil 1.
