Oil recommendations for tractor
Seattle area
This is my first post on this great forum, and I am seeking input and recommendations on selection of a replacement oil for the hydraulics system on my 1-year old Power Trac tractor. It is entirely hydraulic, with 4-wheel hydrostatic drive via four independent hydraulic wheel motors. Additionally, all of the implements are hydraulically operated, and attach hydraulically at the front of the machine. There are 2 hydraulic PTOs to activate the various functions of the attachments. The hydraulic tank is approximately 10 gallons. Hydraulic flows are of the order of 8-9 gpm @ 2500 psi. In other words, the hydraulic oil is the lifeblood for every aspect of the operation of this machine.
The manufacturer {HERE}(made in the USA, btw) supplies these machines with motor oil in the hydraulic tank, and their manual recommends using either 10W40 or 15W40 motor oil for top-off and replacement. The factory rationale for motor oil is economy and ready availability. They indicate, however, that any good quality hydraulic oil of comparable viscosity could be used instead. Some owners have gone synthetic with Mobil 1 of varying weights up to 20W50. Others have used Amsoil synthetic hydraulic oil 5W30 (? formerly ISO46). When operating, the hydraulic oil in the tank will reach 170-180 degrees if working hard such as heavy mowing or brush hogging, despite the machine having a fairly large hydraulic oil cooler. Some owners report empirically that wheel motor strength was improved with higher viscosity oils such as the 20W50.
I plan to change the oil when I reach 100 hr of operation, and would like to replace it with a product which will endure for several hundred hours, barring water or other contamination problem. Input is appreciated.
A good quaility like Chevron "iso Syn" hydraulic in a VG grade 68.
Or look at the specs of whatever is avalible to you and use somthing that has a >5,000 hour ASTM D-943 this test is on most quality hydraulic oil data sheets.
Nice tractor wish I had the yard for it.
bruce
Thanks for your input, Bruce. I will look into the Chevron Iso-Syn. I am wondering whether an ISO68 will perform as efficiently when hot as a 40W motor oil. In one comparison chart {HERE} it seems that 40W is comparable with an ISO100 to ISO150. With that said, perhaps the cold weather hydraulic flow of an ISO150 may be a problem.
I'm not familiar with with the D-943 test, but I will definitely get on track with it.
Thanks for the compliment on the tractor. When we lived in Stockton, CA we had an easy yard to maintain. Out here in the boonies, I need more muscle, especially as I get older. The Power Trac really helps, and factory support is excellent.
Go by the MFG recomemdations, the D-943 test assaults the test oil with a 100C heat with water and a coppper/iron catalyst a very good oil will last >5,000 hours some GPIII oils like the Chevron Iso Syn will go >10,000
bruce
I wouldn't use anything thinner than an ISO 68 hydraulic oil, such as the AW.
Also, Schaeffer's has the HTC #254 in ISO 100 and 150.
Thank you Pablo, MolaKule, **** in Falls Church, and again bruce381 for your input. I am leaning toward an ISO 68 or equivalent, and since mfr has used motor oil, I am also inclined per suggestions to stick with a motor oil formulation.
If we don't get some snow here, I'll have plenty of time to perseverate about a choice before I reach the 100-hour mark on the tractor.
Sorry that I didn't see the follow-up on my original post sooner. I thought the thread died in September after bruce381 posted. Thanks again for your input. Best wishes to all for the holidays and Happy New Year, too.
