I have an 89 gmc 1500 that has been ls swapped with a 2001 5.3l and 4l60e trans.
It has approximately 9.8 to 1 compression, aluminum heads, and a .552 .549 camshaft. This will be it's fourth oil change since I rebuilt the motor and trans 8 months ago and I wanted to switch over to a full synthetic oil.
Truck weighs 4000 pounds, it's a daily driver and a weekend warrior on the drag strip. I drive it very hard, wide open throttle 0 to 100 mph at least 4 times a week then if I goto the track 4 or so passes.
I comute 40 miles round trip, I live in tulsa oklahoma, I cruise at around 2k rpm 70 mph 4th gear locked.
Not sure what other info you may need but I'll chime in when asked questions. Could also use a filter recommendations currently running valvoline conventional 10w30, with standard a.c. Delco filter.
Was leaning towards royal purple but I don't have a brand preference I just want the best protection I can afford for my investment about 100 bucks per oil change is all I want to spend half of that is where I'd like to be. Thank you
