Hi Guys,
Bought a 2012 Ford Focus in late November.
The dealer I bought it from has a "Maintenance for Life" program, meaning they'll change the oil/filter and rotate the tires every 5,000 miles for free for the life of the vehicle.
They use Motorcraft 5W-20 and the great Motorcraft FL-910S filter.
I am concerned about the intake valve buildup issue with the DI engine. As such, I am strongly leaning towards Pennzoil Ultra 5W-20 with the published 5.0% Noack figure.
Other choices would be Pennzoil Platinum 5W-20, although the 12.8% Noack is higher than I would like to see.
And Mobil 1 5W-20 is another possibility with its 2.75HTHS which probably would have a lower Noack than Pennzoil Platinum, I would think.
Seeing the last few used oil analysis for the 2.0L DI Focus leaves me less concerned about fuel dilution issues, but I'd rather play it safe regarding the volatility, buildup issue.
And if only there was an easy way to see if the MC oil was adequate, regarding intake valve buildup, that would be great.
I am historically a SOPennzoil UltraS user, but it's tough to beat free, if the Motorcraft oil is up to the task. I know it's a 60/40 Group III/II oil, but I'm skeptical its Noack is much under 14%.
Any opinions would be most appreciated.
Thanks,
Gary
Thanks,
Gary
