Originally Posted By: FordCapriDriver
I was just wondering if you guys think it's too high, or that it might indicate a problem.
I've always thought the more oil pressure the better but since reading BITOG threads i've realised you have to find a good compromise and balance between pressure and flow right?
FCD, what you are describing is exactly what every 1970s car I owned did on cold starts.
Peg the OP guage until it warms up, then drop to 15-20psi hot idle.
Nothing wrong with it...it's normal.
the high pressure means that the viscosity in your bearings is such that it doesn't have as much side leakage (bearings draw only that which they need from the pressurised galleries), and the artifact is oil pressure.
Your bearings are getting all the oil that they need...as the oil thins with heat, they need more, draw more, and the pressure drops.
There's a school of thought, inspired by 101, and another vocal poster who do NOT understand the hydrodynamic theory that you need to pump an oil pump volume worth of oil through the engine every revolution to "lubricate", but they are wrong.
If you want, I've explained "side leakage" in
this thread on how bearing are designed and work.
Flow is a result of lubrication, not lubrication in and of itself.
