1999 Buick Park Avenue. Non-supercharged with optional driver information center.
The gas gauge quit on the instrument cluster, so the shop took it out and took it to the GM dealer to be sent in for rebuilding. This was after they tried to fix the car with 2 different used clusters... one wasn't the right one, and the second one had a bad gas gauge as well.
3 days and $300 later, instrument cluster is back from the GM dealer. It is reinstalled and the gas gauge works fine.
Only problem is now the oil pressure reading is at 128 psi... engine running or not.
Shop is sort of at a loss as to what isn't right with the oil pressure reading. This was a bit of a nightmarish fix to begin with.
Suggestions as to where to start?
