Oil leaking from base/gasket.
MI
Thers always very little oil leaking. I used Valucraft, AAP, Purolator, Fram Tough Guard, Hyundai filtesr.. all of them leak.. all of the gaskets were fine. I tried doing hand tightened..still leaks.. tried tightening with a oil filter wrench.. still leaks.. what could be wrong?
How is the boss finish where it mates to the gasket? If there is a deep scratch it would do it. Perhaps there is machining defect and that flatness is out of spec? What kind of car?
add to the above list of potential causes:
A bent threaded shaft will cause the filter to seat crooked and not seal.
A buildup of crud on the gasket seating surface.
Filter mounting base surfaces are to be machined smooth. It could be yours isn't. A rare occurance but not that uncommon.
