Oil in sparkplugs dips: Toyota 1AZ-FE rocker cover gasket?
Reunion Island
Hi,
I had no problem before noticing this, but when I replaced spark plugs on wife's new old 2001 RAV4, spark plugs where drowning in motor oil after removing ignition coils.
If I don't care about the leak, can this staying oily around cause problems in the future? Should I replace valve cover gasket?
This gasket is really easy to change and around $7 on ebay. You should do it.
Soaking the coil boots in oil does them no favors.
Just get a valve cover gasket kit and the kit comes with spark plug o-rings/gasket.
It is easy to change as long as you have the correct tools.
No cheap parts underneath worth changing except oil.
