I was checking my plugs, and I saw on the rightmost plug it had oil at the washers and a little on the thread, so I look into the hole and there is a bit of oil there. It has happened before 2 times (once in another spark plug hole), but I cleaned it up using q tips on a stick. The plug itself looks clean , just the oil seems to be coming down the hole from halfway.
I tightened the valve cover bolts a bit for that side of the engine, which might help... but I wonder what this very small leak is from!
Its a 1995 Civic DX (1.5 l SOHC non vtec).
