Originally Posted By: Torquejumper
I do not mean to criticize your coworker in any way, but some of the inexperience Honda owners out there sometimes claim that their Vtec is not working when it is. On a bone stock 94-2001 Gsr (B18c1), assuming the car is not a custom hybrid 1.8l build such as a Ls-Vtec etc., the Vtec engagement is not that audible. Based on a couple bone stock gsr I've driven and worked on so far, you won't be able to hear the Vtec crossover. If you did, usually it was very faint or barely noticeable. On the other hand, to be able to noticeably hear the Vtec transition, you can run an after-market intake or take off the top half cover of the stock air filter box. This will expose the stock cone filter inside. If you did this, I guarantee you will hear Vtec if it was working correctly. Also, having a header and exhaust as well will help amplify the sound. Now, I'm only assuming that your coworker's car is bone stock since you didn't give me enough information to go by.
If his car wasn't bone stock, then that's a different story. Vtec in this case could be because of a mechanical defect or something else. I do know for a fact that Vtec won't engage if the oil level is too low or if the car is not up to operating temperating. Also, if the Vtec solenoid is defective or not plugged in then Vtec won't work either.
I'm pretty sure your coworker knows that there are three available 1.8l motors that comes in the 94-2001 Acura Integra models. One is the 140hp Non-Vtec motor (B18b1) available in the Ls, Gs, SE, and Rs trim, and the other is a 170hp Vtec motor (B18c1) available in the Gsr trim. The last motor is also a Vtec motor with a 190hp Vtec motor (B18c3) available only in specific years of the Type R trim.
I don't think oil is the problem here as long as the oil meets factory specs if you exclude mechanical errors related to Vtec engagement. I'm not quite clear what your coworker meant when he said Vtec is not kicking in. Is he basing this on what he hears, feels, or actually know?
According to my knowledge, Vtec is like a two stage program. Vtec engages at around 4.5k (not noticeable unless you got some mods), and what you hear at around 6k, what people commonly call Vtec crossover, is actually the secondary butterflies opening up.
Yeah I should have been more specific about his car. It is the Gsr 1.8 and it is mildly modified with air intake,headers and full catback exhaust. He described it to me that he cant hear it at all since the oil change nor does he "feel" the performance at higher rpm's . I have never driven it but its in good mechanical shape with no motor problems etc. He thought it could be the screen but I thought id ask on here to see if anybody had had a similar problem with their vtec motor and different oil. he says he has always ran 5w-30 in every type of oil ran in his car.Thanks for the advice
