I have an old Tecumseh 2.5HP motor that's going on a motorized bike I'm building for short distance commuting to help save on gas. During the summer it'll get started in the cool of the morning, probably around 70 degrees but the motor is going to also be working hard in 100+ degree heat. During the winter it will get at lowest around 35-40 degrees.
My initial thought is to run Rotella SAE30 in the summer and 15W-40 in the winter.
Reading through the threads here, some people run Rotella T6 5W-40 full synthetic just because the amount of oil that is required is so small so cost is not an issue. Since it's synthetic, the high heat of an air cooled engine and oil breakdown is not an issue?
What route would you guys recommend? I know I probably cant go wrong running SAE30 for the summer, it's more cold start protection in the winter I'm not too sure about. Is the full synthetic route going to be worthwhile or I should I just stick to the cheap and proven dino oil?
