Your better quality engine installations will be FWC and a slightly higher thermostat temp. Many marine engines have oil coolers.Depends on the engine really. But understanding that marine applications are usually at or near max throttle and RPM 250F isn't uncommon.
Aluminum heads etc, should lower that temp as engine temp is usually quite low due to using seawater cooling.
