Originally Posted By: quantim0
Originally Posted By: Bandito440
If it's tuned and you're not especially worried about sticking to 5w30 API SN, the turbo Subaru crowd generally uses 40-weight oils:
Rotella T6 5w-40
Mobil 1 Turbo Diesel Truck 5w-40
Mobil 1 0w-40
Castrol 0w-40
WM has all of these in jugs.
I'm undecided of switching to a 40w. I think it would be helpful overall, but the car only has 8000 miles on it, so still possibly covered by warranty. I have geico mechanical breakdown insurance that I'd count on for an engine failure more than Fords warranty. But if a good 5w30 can handle a 7500 OCI and not shear down I don't see a reason to switch.
I may switch because the odds of a lubrication related failure are minimal overall compared to the other failure possibilities with this engine.
I'm pretty sure you voided your powertrain warranty with the tune. If you play with their ECU then the things that would break related to the tune are limitless.
Rotella T6 5w-40
Mobil 1 0w-40
Castrol 0w-40
