Help! 30 micron pleated mesh filter with 16psi differential (across the filter) bypass valve. 20W-50 oil with 100C cSt = 20.5 and 40C cSt = 181.8 and Viscosity index is 132. Oil temperature is 140 to 200F and measure pressure (downstream of filter) is 70 to 90psi. Any idea or way I can calculate the dp across this filter under given conditions?
