Originally Posted By: DrRoughneck
Originally Posted By: OneEyeJack
It's also possible that with a larger filter the oil will pass thru the filter element just that little bit slower. That could mean improved filtering. Over the life of the engine every little bit helps. What do you think?
If 1cm2 of filtering material flows 1cm3 of oil per minute under 5psi of differential pressure, and the pressure is identical inside a small and a big filter, then the bigger filter will let more oil through during the same amount of time.
A bigger filter flows faster, not slower.
You have to always understand that the oil supply is coming from a positive displacement (PD) oil pump ... not a gigantic "oil tower" like the water in your house. It's fed a forced volume by the PD pump, and the seen oil pressure is the result of forcing X GPM through a fixed resistance to flow (ie, the oiling system as a whole).
If the PD oil pump is not in pressure relief, then it's putting out X GPM at Y RPM. And in that case, all of the same volume of oil flow is going through the oil filter regardless of how small or big the filter is.
Therefore, as BrocLuno and OneEyeJack pointed out, with a larger filter with more media area, the oil flow velocity will be slower than in a smaller filter - and hence the delta-p across the filter will also be lower. and farther away from the bypass valve setting. But the same exact oil volume will be going through them both.
BTW, the pump pressure relief valve is before the oil filter, not after like shown in the schematic post #1.
